Author Topic: REW questions  (Read 45493 times)
Re: REW questions
« Reply #285 on: November 08, 2019, 08:56 »
Mine beta 26 and asio 2.14 was working perfectly on a 2012 laptop running windows 7, the moment I upgraded to windows 10, the display audio, intel HD graphics 4000 not working ! Still not working.... sigh....
Beta 27 had some issues I heard
Re: REW questions
« Reply #286 on: November 08, 2019, 15:49 »
Anybody having problems on rew beta 26 on windows 10?
Problems I'm facing is MV -10 but for subwoofer reading is sometimes gets to be soft & loud readings.(sorry just took a snapshot from phone)
I believe the acoustic timing also have some issues.
Try resetting ASIO configuration to default, worse case reinstalling ASIO.
Highly recommend USB MIC is attached directly to laptop (not via some USB port expander).
When using REW, try to make sure it is the only app running.
I notice on my workstation, REW-ASIO will go a bit ting-tong when there are busy processes in the background (network transfer, HDD transfer, CPU busy). REW-JAVA always okay. When it go ting-tong, can hear the audio sweep got crackle and sometimes distorted. When it really go full siao-ting-tong, I have no choice but to reboot PC.
Re: REW questions
« Reply #287 on: March 30, 2020, 22:32 »
anyone using beta 45 V20 ? any issues? just upgraded to this version, gonna bring out the old mic soon, havent touched the microphone for quite some time, rusty now, suddenly from beta 26 its now 45! 19 versions ahead!!! Nov2019 to March 2020
Offline Djblackfm
Re: REW questions
« Reply #288 on: March 30, 2020, 22:34 »
I think Im same as you as well. Hahaha. I never touch the mic after my last calibration .
Re: REW questions
« Reply #289 on: March 30, 2020, 22:38 »
lol, gotta get down to work again... sigh, another tiring calibration journey, hopefully this is the last!! thank god i still have the files i can refer on previous work done. The thing with the calibration thing, after sometime you tend to forget also. Anyway, good refresher.
Re: REW questions
« Reply #290 on: March 30, 2020, 22:55 »
Tough work but rewarding. I have not even recalibrated my system after adding a power amp. Lazy.
Re: REW questions
« Reply #291 on: March 30, 2020, 23:08 »
yea man.. i know... tiring... hahahaha
Online sevenz
  • Trade Count: (+18)
Re: REW questions
« Reply #292 on: April 01, 2020, 00:00 »
nope still on 5.19 ha...
are there any benefits to move to the beta version? Scared not stable
Re: REW questions
« Reply #293 on: April 01, 2020, 08:46 »
Oh, I think the later version, v5.20 post beta 20, fixes the timing reference issues . Best use that, 5.19 still has some problems with acoustic timing reference. As I use this feature to time align the speakers and subwoofers, it was important to get the REW version up to date that has timing issues fixed . Unless u don’t use this feature, then it’s ok probably. Do check out there fixes, I lost track after 5.20 beta 26. The newer ones now allows measurements for impedence as well
Re: REW questions
« Reply #294 on: April 01, 2020, 09:04 »
I’ve gone ahead to update to v5.20 beta 43, if there are problems, I’ll revert to my previous working version, beta 26, beta 26 tested working very well.
You can try zoom zoom upgrade straight to v5.20 beta 26 if concerned, but v5.19 definitely has acoustic timing reference issues where measurements are not really accurate
Re: REW questions
« Reply #295 on: April 01, 2020, 09:45 »
beta 46 out liao
Re: REW questions
« Reply #296 on: April 02, 2020, 16:00 »
beta 46 out liao
Ok thanks, I’ve just loaded 46. So many changes since. Will try out soon, report my findings if this version is good enough. Lotsa timing reference fixes up to beta 29
Re: REW questions
« Reply #297 on: April 05, 2020, 17:35 »
Verified beta 46 very good, and stable. The acoustic timing reference measurements are very accurate ! Impulse measurements, spectrogram, RTA, all very good. No issues getting it to work with windows 10 laptop. Can use this version, nice
Offline lcheetec
Re: REW questions
« Reply #298 on: May 03, 2020, 08:31 »
Newbie to REW where. Just downloaded and installed 5.20 beta 49.
Wow, it's a giant piece of software. I was eager to get going so I installed it on my laptop (unfortunately, the 32-bit version, I couldn't get the latest Java RTE to install on the laptop), connected it to system and UMIK-1 and starting sweeping.
I did one 20 ~ 20kHz, several 20 ~ 1kHz and to 200 Hz. The latter was with and without the Starke SW12 in the system. Wanted to see who was contributing to the peaks and dips etc.
Fun, although it'll be a while before I understand everything in order to dial in settings on the miniDSP's I have in the system. My speakers are a DIY pair of Siegfried Linkwitz's LXmini including the +2 stereo subs.
Daniel
Sent from my Mi MIX 3 using Tapatalk
Re: REW questions
« Reply #299 on: May 03, 2020, 10:29 »
We'll be here if you have any qns.
