Author Topic: Premium Spikes/Bases/Float/Cones/Anti-Vibration/Suspension/Ebony - new update  (Read 82 times)
Offline littlemart
    • E-Store Littlemart
Cones / Base
For use with audio item like speakers / DACs/ amplifier etc to improve the sound quality.
Ball Bearing Cone (Limited set available. While stock last)
Holds details given is both clear and soft natural. Clear + soft + nature , these three words to describe the use of parallel , points to a lot of people want to reach the realm .
Material : Aluminum, anodized in silver or black, high-tech ceramic ball, with Screwable (supplied with M8 bolts)
Usuable height  30 mm (infinitely adjustable)
Dimensions: 20 mm (top section),
30 mm ((bottom section)
(Best Performance Load:1x cone can support +- 10kg load, 3x cones support 20-30kg load, 4x cones 20-40kg load and so on....)
Set of 3 -  Selling at $45
Set of 4 - Selling at $60
S1 vibration-proof cones for speaker/audio equipments
Size: 24mm * 25mm
Material: Alloy
Package: 3pcs in a box - Selling at $33/box
S2 vibration proof cones for speaker/audio equipments
Size: 34mm * 37mm
Material: Alloy
Package: 3pcs in a box - Selling at $39/box
B1 vibration proof cones for speaker/audio equipments
Size: 28mm * 60mm
Material: Alloy
Package: 3pcs in a box  - Selling at $45/box :)
Spikes / Bases
Use for audio equipment like Amplifier, DAC, Speakers etc to prevent vibration for better sound improvement. Can support up to 200kg of weight. Made using Stainless Steel and Black Stone material .
mini White (Spikes & Bases) upgrade with Ebony Housing
There is a significant improvement with the upgrade ebony kit, to ensure it add enough music taste and make the music playback more appealing ! Turning a CDP to be like a LP sounding and make an ordinary piano like a grand piano sounding ! As compare to the like of Japan Tilgon and some other more establish international products, the pricing is significant much cheaper.
Use for small/mini - medium size audio equipment like Amplifier, DAC, Speakers, Stand, Hifi rack etc.
Base -  (Diameter 23.5mm,  Thickness 6.5mm)
Spike - (Diameter 23.5mm,  Thickness 11mm) (Come with 3M tape)
Bundle Set A (3 pcs set) - Selling at $40/set
Bundle Set B (4 pcs set - Selling at $50/set
Black Gorilla 1 - Spikes & Bases
Use for medium size audio equipments
Base   Selling at $8/pcs     (Diameter 39mm,  Thickness 11mm)
Spike Selling at $10/pcs   (Diameter 39mm,  Thickness 26mm) (Come with 3M tape)
Bundle Set A (4x Bases and 4x Spikes) Selling at $60/set with box (Save $12)
Black Gorilla 2 - Spikes & Bases
Use for medium big size audio equipments
Base   Selling at $9/pcs     (Diameter 49mm,  Thickness 13mm)
Spike Selling at $14/pcs   (Diameter 49mm,  Thickness 35mm) (Come with 3M tape)
Bundle Set A (4x Bases and 4x Spikes) Selling at $80/set with box  (Save $12)
UFO Float
[/img]http://
UFO floating shell  component material is a high performance anti-vibration metal - magnesium alloy .  UFO float is up to 77mm in diameter can give a better stability
Sense of hearing this vibration characteristics of magnesium alloys has no metallic sound , and low-frequency is very good , with thick treble.
The vibration of the structure, using elastic suspension floating leisurely way , this way can eliminate vibrations even more thorough clean, so that portray the sound field is more delicate , more smooth contour. The sound field structured, precise positioning, three-dimensional sound image up ; The overall effect is very well balanced and what we said has upgrade the sound to another level !
They come with standard flat head and 1 spike head. For convenient to use in any setup
Load capacity: 15 kg (set of 3),  20 kg (set of 4).
Set of 3 -  Selling at $105
Set of 4 - Selling at $140
One Stop Audio E-Store:
Promotion item: https://littlemart.wordpress.com/promotion/
Follow my E-Store to get update with the latest Group Buy Deal: https://littlemart.wordpress.com/2017/01/12/group-buy-section/
Mobile: 97223884
littlemart2013@gmail.com
http://littlemart.wordpress.com
Order: Mailing / AMK Pickup in evening
