Author Topic: Oppo UDP 203 & 205 UHD players  (Read 207878 times)
Offline InnocentBlood
Re: Oppo UDP 203 & 205 UHD players
« Reply #1185 on: May 19, 2020, 14:45 »
I got a $2,000 12 metre-HDMI cable connected between my projector and my Blu Ray Player Video HDMI outlet before.  Every now and then, I got the handshaking issue.  Once in a while, video on for a brief few second and then handshaking resumes again.  Sometimes, I will get a continuous blackout ....you must shake it a bit...or let the system rest and hope it restart and everything be OK.
Then I switch to optical HDMI and replaced the $2,000 cable with it.  NO MORE PROBLEM.   100% reliable, you switch on, it work each and every time.   I am so pleased that I bought 5 more optical cables and made my home theater completely HDMI optical.
That is why from your description, I knew it was the HDMI cable.
yes that was the advice I got from a member at AVForum as well. these cables were laid for me by my installer just before the CB period and I have reported the matter to them. both cables are currently running inside my false ceiling and when the workers are available, I should be able to have them replaced with optical HDMI cables.
Sex N' Violence
Undesirable Publications
« Reply #1186 on: May 19, 2020, 17:47 »
You can’t really compare a cable not designed for 18Gbps with one that was.
Online Djblackfm
« Reply #1187 on: May 19, 2020, 18:49 »
I think they should resurrect the brand and come up with new 4K Blu-ray player lineup featuring support for HDMI 2.1 etc.
I kinda regret having to sell off my Oppo 203.
I'm the culprit who bought your OPPO
« Reply #1188 on: May 19, 2020, 19:03 »
LoL. How’s the player? Still going strong I suppose?
Online Djblackfm
« Reply #1189 on: May 19, 2020, 19:11 »
Still going strong . It's a player that able to play Dolby Vision.
« Reply #1190 on: May 19, 2020, 19:14 »
good to know.
Offline jonlee
« Reply #1191 on: May 19, 2020, 20:24 »
good to know.
Des, u wanna sell your LX500?  ;)
« Reply #1192 on: May 19, 2020, 20:25 »
U guys really keep track of what gadgets I’m using eh. LoL
Offline Ccyao
« Reply #1193 on: May 19, 2020, 20:40 »
I use 10m optical hdmi cable from my Denon 6400h to my Benq W5700. Still encounter handshake issue occasionally.
« Reply #1194 on: May 19, 2020, 21:07 »
Yep. Nothing is for certain. It depends on the quality of the optical cable itself. My 15m optical cable out of sudden just kaput w/o warning. Luckily the shop willing to do a one to one exchange for me ROC even after 1 year. Now the replacement cable is doing fine (touchwood).
Offline Ccyao
« Reply #1195 on: May 19, 2020, 21:24 »
Wow! That's very nice of them!
Offline Desperado
  • Don't Worry Be happy
« Reply #1196 on: May 20, 2020, 21:55 »
In my case, brand does play a part for a quality of HDMI optical cable.
Running 10 m HDMI cable from Receiver to Oled TV (ARC).
Monoprice Certified HDMI cable (Copper) - Sound dropped for split second every 1-2 minutes on pass through. No problem with PCM, but SQ suffer big time (soft and no punch).
Vention Optical HDMI Cable - Totally no sound
Aztebe Optical HDMI Cable - Same issue with Monoprice Copper HDMI Cable
Ruipro Optical HDMI Cable - all is good
Online Audio
« Reply #1197 on: May 20, 2020, 22:22 »
.....Fibbr Optical HDMI Cable - all is good.
Offline Ccyao
« Reply #1198 on: May 21, 2020, 00:13 »
I'm also using Ruipro. Most of the time OK. But the picture will drop for 2-3 sec once in a while.
« Reply #1199 on: May 21, 2020, 23:08 »
Go into your BenQ settings, set the hdmi equaliser to a higher value. See if u still encounter Signal drop out. This setting is available in isf mode
I’ve been using this brand from China “ Moshou. Fiber hdmi 2.1 15 meters, smooth and no stutter , no issues so far even on 12k material
Monoprice is the worst from my experience, i would avoid that. Not sure about the new batch now, but once bitten twice shy
