Author Topic: Oppo UDP 203 & 205 UHD players  (Read 198565 times)
Offline kingajit
Re: Oppo UDP 203 & 205 UHD players
« Reply #1155 on: May 31, 2019, 21:03 »
Agree i am using these too!
AVR : Denon 7200 WA,
Fronts : Monitor audio GX 300
Centre : Monitor Audio  GX 350
Surrounds : Monitor Audio GX100
Back Surrounds : Monitor Audio Radius
Atmos Front & Rear : Deftec Pro 1000
Subwoofer: 2 x JL E112
DA & T stereo amp for Front speakers
Emotiva XPA 1 Gen 2 monoblock for Centre speaker
Marantz power amp for surrounds and back surrounds
Marantz power amp for four Atmos overhead speakers
Oppo 203 blu ray player
JVC projector x7000,
Carada screen 235:1 110 inches
« Reply #1156 on: May 31, 2019, 21:07 »
Awesome ! So far I have not heard a single person say doesn’t work!
Offline Audiolab
« Reply #1157 on: May 31, 2019, 21:10 »
Works perfectly for me as well! A must have to improve the Oppo!
Offline ngsk
« Reply #1158 on: May 31, 2019, 22:04 »
This DIVINI SP-40 footer is great stuff for OPPO 20X player @ a great price as well. Testing it last Sunday n it never leave the 205 liao. ;D ;D ;D
Offline trickle
  • Only the penitent man shall pass...
« Reply #1159 on: September 26, 2019, 10:27 »
got a question about repairs.
in the event that our players (either 203 or 205) go belly up, who do we go to for repairs locally?
I know the guys in the US can send it back to OPPO.
Offline Tiktokape
« Reply #1160 on: September 26, 2019, 12:14 »
If your unit is a local set, just bring to Sound Affairs no?
Offline trickle
« Reply #1161 on: October 02, 2019, 10:14 »
Mine was from Anson Audio.  It is a local set.
Do you know if Sound Affairs services out of warranty Oppos?
Offline Tiktokape
« Reply #1162 on: October 02, 2019, 10:19 »
Anson’s set still comes from Sound Affairs unless it is during the pre-SLT days. In all cases, just go straight to Sound Affairs.
Offline trickle
« Reply #1163 on: October 02, 2019, 10:22 »
Brilliant.  Thanks for the info, buddy!
Offline InnocentBlood
« Reply #1164 on: April 05, 2020, 00:34 »
New FW UDP20XTW-65-0131 out on OPPO Digital Taiwan website : http://www.oppodigital.com.tw/support.php?tab_id=1
hi bros, i'm trying to access the latest firmware for my 205. mine is the taiwan set. since this link is no longer working, would any of you know where else I can get the firmware please? i tried the US site but the firmware is not detectable by my 205 and I'm unsure why. my previous firmware upgrade was from the US site and that seemed to work.
any ideas please?
Sex N' Violence
Undesirable Publications
Offline Ccyao
« Reply #1165 on: May 03, 2020, 15:25 »
Hi, anyone knows If there is a way to make audio signal coming out from both HDMI (Main) and (Audio) at the same time?
When I connect to both, audio signal only comes out from HDMI (Audio). No audio signal from Main.
« Reply #1166 on: May 16, 2020, 17:46 »
are any of you using the 205 with the JVC N7? I seem to be having trouble with getting the 205 to output proper HDR info to the N7. with the HDR setting as Auto, I only get 1080p when playing UHD discs. when I set to Dolby Vision, I do get UHD resolution but the BT2020 profile doesn't appear. my 205 is currently connected directly to the N7. should I try to route both audio and video via the Denon 8500 instead?
any input would be appreciated, thank you :)
Sex N' Violence
« Reply #1167 on: May 16, 2020, 18:11 »
This just happen recently or since day 1?
« Reply #1168 on: May 16, 2020, 18:15 »
I first discovered this a month ago but I didn't get a chance to troubleshoot. today I had a chance to check with other UHD discs and I found out I just can't seem to get the Oppo to push out HDR info to the N7 while connected directly. I googled and at least one other guy on the internet had the same issue with another JVC but he managed to solve by using the Dolby Vision setting.
https://www.stereo.net.au/forums/topic/250253-oppo-udp-205-not-outputting-4k/
i've sent an email to Oppo tech support. meanwhile I'm still trying to source for the TW version of the latest firmware for the 205...
Sex N' Violence
« Reply #1169 on: May 16, 2020, 18:19 »
Sorry can't help you out here since I no longer using Oppo player...Any member here can help out. Pls chip in.
But no harm trying to connect it direct to the AVR (8500) and then output to the Projector (N7). Please make sure, the 4k Signal Format setting in the AVR - if available - is set to Enhanced. You can find this settings in Video section of the menu of your AVR.
Also try changing to a different Input on your Projector (from Input 1 to Input 2) and see if it helps. BTW I hope your cable is a true certfied HDCP2.2 that is able to pass through a full bandwidth @18Gbps? Lastly, change your Inputs on your AVR to one of the Inputs nearest to the Output ports of your AVR (8500) and see if it helps.
https://denon-uk.custhelp.com/app/answers/detail/a_id/4377/~/hdr-passthrough-not-working
« Last Edit: May 16, 2020, 22:51 by desray »
