Author Topic: Help! My system sounded unbalanced...  (Read 15781 times)
heeyeng
« on: April 25, 2002, 23:00 »
Dear forumers, for some reason, I hear that my system that is bought just 2 weeks ago, well, sounded a tiny little bit unbalanced. This is hard to explain but please let me try...
Have you ever notice that your system, the right channel will produce more treble than bass, and the left channel will produce more bass than treble? That's what I found from my system. I am listening to mostly female vocals and sexaphone (so more treble in a sense). At first few days of listening, I have notice a slight off to the right side for every single disc, every single track I play. Then I did an funny experiment, I unplug the right channel signal of AMP, leaving only 1 channel attached to AMP now, and I switch between pluggin in to right and left input of AMP. Well what I notice is when plugging into right input of AMP, the sound is much forward, more treble to be heard (of course only from right speaker), and vice versa when I plugged into left channel I heard less treble, but more bass...
I've switched between speaker, cables, and interconnect, but the effect is the same, so no doubt about those other elements.
Regarding this right = more treble and left = more bass, can anybody confirm this findings? I say again, it's not so much different, but it's just very subtle but noticeable, especially with good interconnects... Else I would guess maybe something is wrong with my amp...  ???
Offline quekky
  • Lift your music
Re:Help! My system sounded unbalanced...
« Reply #1 on: April 25, 2002, 23:15 »
could be your room, my room also got such effect
Offline Spunky
« Reply #2 on: April 25, 2002, 23:26 »
Try this:
with the connections unchanged, switch the location of the spkr such that your amp's left ch is powering the right spkr and vice versa.
this will narrow down the possibility of faulty electronics.
**go further by switching L-R of the interconnect at the source end.
if problem remains, most likely room acoustic
The Ultimate answer to Life, the Universe and Everything is...
heeyeng
« Reply #3 on: April 25, 2002, 23:27 »
Thought maybe that's the reason too, but until I put my right ear (only right ear) close to the speaker when doing the comparison, left speaker and right speaker produces different sound, even if the source is from 1 channel... quekky maybe you can try to double confirm with your system? May not be the room problem...
Many years ago when I was very young, I heard a older friend told me about the design of walkman, whereby the right and left channel actually are amplified slightly differently... or is it recorded slightly differently... that's what constitute to 'stereo'...
Can anybody confirm with that?
heeyeng
« Reply #4 on: April 25, 2002, 23:31 »
Did that before, after speaker switching place, sound also switching place, becoming now left = more treble, right = more bass...
So still back to 'square one'.
« Last Edit: April 25, 2002, 23:32 by heeyeng »
Foodeater
« Reply #5 on: April 26, 2002, 01:31 »
Owned it for 2 weeks you say?
Try to break in the speakers a wee bit more with some full range material... or get a pair of similiar speakers to do some testing perhaps? It's probably the only way to determine whether if it's the amp or whether it's the speakers...
Tell you an experience I had: I wasn't aware that even headphones needs breaking in... I was approached by a guy online who complained that his Sennheiser HD497's probably damaged because it didn't sound right, and I suggested that he leave his cans blasting, and it worked well fortunately.
So why not try it for a while, and it might sound even again, probably because the rubbers would have stretched evenly by then for all the drivers to work the way the designers wanted them to work... :)
Good luck!
Offline quekky
  • Lift your music
« Reply #6 on: April 26, 2002, 01:53 »
not very sure about your system
for mine, i use 1 source (1 amp, 1 side of the channel), use a sin-wave tone gerenator to create wave files, burn cd, then use SPL meter to measure each speaker @ 1m @ 1W@1khz individually. both plots come out different, so i know it's my room or speaker
Offline aloychan
  • Always a Master & an Apprentice, no more no less.
« Reply #7 on: April 26, 2002, 08:49 »
Could you tell us how old is your system, 1 or 2 wks old ??? I suggest you run-in first, say abt 1mth. If after that 1mth you still have the same problem, call your dealers or sellers for answer.
Not likely rm, since you move your ear so close to the spks to hear the difference. Hv you move your system to another rm to do the same test ???
Could it be your spks connector on the back of your AMP.
Anyway, which brand of AMP you using.
Just my 2Cents.
Offline cjctan
« Reply #8 on: April 26, 2002, 15:22 »
Hi,
I have similar problems until last week.  For my case, my old integrated amp was the main cause.  I used to positioned my right speaker a bit forward than the left.  Although improved by a little but still not good enough.....
This problem was finally solved when I changed my amp last week :)
KC
Offline cjctan
« Reply #9 on: April 26, 2002, 16:20 »
Interesting...what are the 2 amps in question?
The problem amp is a HarmanKardon 6500 and i bought an Arcam Alpha 8 from fellow forumer, Aiky ;)
heeyeng
« Reply #10 on: April 26, 2002, 22:37 »
Thanks people for all your inputs! :)
I do not have a SPL meter... so can't do the experiment that you told. Will only use ears to judge then. Well I don't hear the 'loudness' as a difference here, loudness are to my ear, the same. However, it's rather more of a tonal balance, between left and right channels...
You know what, this afternoon I did another experiment, it's simple and you all can try also: I took the earphone of my discman, just put right plug to your right ear, then try with left plug also on your right ear, I am certain, very sure, that I hear different tonal among 2 plugs, right side got more treble, left side got more bass!
Please try it out, and tell me your findings here can? ;)
Is that the way that recording studios recorded in general? Maybe this is a norm just that we doesn't know?  :)
Happy listening... :)
heeyeng
« Reply #11 on: April 26, 2002, 23:41 »
Which case is it?
Case 1. Agree, speaker is definitely matched.
Case 2. I feel that in stereo, treble in the right tends to be tiny bit more than the left, bass in the left is tiny winy bit more than right.
Case 3. Yes, mono has no difference.
heeyeng
« Reply #12 on: April 28, 2002, 23:41 »
Thanks everyone for your reply...
I finally concluded that it's the amp problem that's causing the unbalance. What I do to confirm is, I took a mono signal (radio mono) as input to the amp, turn the balance knob to left, listen, then right, listen... At first I couldn't hear the difference, but after a little bit more listening, I really can hear that the right channel produces clearer sound, left channel sound like having a thin cloth on it...
Well, do I have a case here to return for repair?  :-[ Reason being the difference is kind of small, till maybe the dealer can't listen to the difference, and just reject to replace another one for me...
Another thing, heard this model is not importing to Singapore anymore, it's a Rotel 931 Mk2.
Gosh, do you guys know if send back for repair (under warranty), what will they do? Replace some components and return you the old thing (which I'm just afraid if QC is not good enough will cause more harm than good), or they will replace a totally new one?  :-\
MLK
« Reply #13 on: April 28, 2002, 23:57 »
Is the room square or rectangular? Is there any part of the room which has an indented portion to either side of the 'side wall'? Meaning not pure rectangular (inclusive of furniture).
Offline Lord Hawke
  • Soli Deo Gloria
« Reply #14 on: April 29, 2002, 00:07 »
Just to share a similar experience, heeyeng....
I was halfway through my hifi acquisitions when I encountered this problem.  Gotten my amp, speakers and speaker cables, but no sources yet.  I decided to hook up my old Sony Discman using a mic-to-RCA interconnect to my amp so I can assuage my hifi cravings.
Imagine my surprise to get the same problem as you did!  :P  The right side was sounding louder than the left.  Tried everything, swap cables, change phase, position speakers, eventually use the Balance dial to correct the imbalance.
Well, tonight I found the culprit.  When I plugged in my new CDP, like magic, everything was normal!  :o  Likely the mic jack side of the interconnect wasn't as tight enough or my Discman is koyat. Oh well...
Wah, I sure hope it's not your amp like you suspect.  Perhaps if you could try a different source altogether?  ??? It might help.  Ok, so let's say the amp is at fault.  Changing the source should not affect the imbalance.  But if it did, then ah...
Hope this helps.  Good luck!  ;)
```-0
Lord Hawke
```-0
Lord Hawke
