Author Topic: DIY Fullrange Speaker Driver  (Read 8988 times)
ghemml
Re: DIY Speaker Tranducer
« Reply #30 on: January 04, 2017, 14:37 »
Spider diameter remain the same, the bigger base is for the field coil motor
Offline arithon
« Reply #31 on: January 11, 2017, 20:35 »
absolutely cool project!!  ;D
ghemml
Re: DIY Fullrange Speaker Driver
« Reply #32 on: March 12, 2017, 22:23 »
Another 6.5 inch cone using different paper
Offline jaffrie
« Reply #33 on: March 13, 2017, 01:07 »
wow hats off to you Sir.
May I ask, who does the machining
work the basket ?
ghemml
« Reply #34 on: March 13, 2017, 07:50 »
work the basket ?
Thanks, i use cnc milling to machine the speaker basket.
*Never read your question properly. Machining done in Malaysia.
« Last Edit: March 13, 2017, 12:31 by ghemml »
ghemml
« Reply #35 on: March 13, 2017, 12:47 »
@jaffire, I don't have a fix vendor for my fabrication work. But for metal you can ask "steed" from this forum.
ghemml
« Reply #36 on: March 15, 2017, 17:02 »
Cone construction completed
« Last Edit: March 15, 2017, 17:04 by ghemml »
Offline tmaseq
« Reply #37 on: March 25, 2017, 02:37 »
Hey ML
Look great, sound clear I like.
LM219 | Custom 12AX7 preamp | Marantz CD72 Mk II SE | TDA1541A NOS dac | Thorens TD 165 | Lenco L75, L78, L75S | ifi iPhono phono pre | Diy Visaton B200 + Visaton BGS40 open baffle speakers | Sanyo Plus Series T55 tuner | Clones Audio 25pm monoblocks + AP! pre | Khozmo dual mono passive preamp | Diy LS3/5a type mini monitors
ghemml
« Reply #38 on: March 25, 2017, 20:02 »
Offline puremilk
« Reply #39 on: April 29, 2017, 19:41 »
No listern,no comments! : :o
Offline hasbro
« Reply #40 on: July 28, 2019, 20:34 »
bros. i agree. so so his stuff....
