Author Topic: 4k media player NVIDIA SHIELD Android TV  (Read 98584 times)
comfortablynumb
Re: 4k media player NVIDIA SHIELD Android TV
« Reply #450 on: August 02, 2020, 11:59 »
U can use NFS protocol for better handling of bandwidth when streaming higher bitrate. SMB v2 and v3 is fine too these days.
Not just only the Pro model will support DV and Atmos for Netflix. Even the normal Nvidia Shield TV 2019 will support that as well.
And yes, all using BD lite menu.
Many thanks for the clarification.
Anyway, the Pro is OOS on Q10...sigh
« Reply #451 on: August 02, 2020, 12:01 »
If u use mostly for Netflix streaming and also all your content resides at NAS and no external HDD connected to it, then the cheaper Nvidia Shield TV 2019 (cylindrical shape) will suffice.
Offline dbchoong
« Reply #452 on: August 02, 2020, 14:22 »
You can buy from Nvidia USA. And make use of a shipping service like ezbuy.
Shield TV: US$149.99 (S$207)
Shield TV Pro: US$199.99 (S$275)
ezbuy shipping from USA maybe S$10-$15.
I got my Shield TV 2019 that way. Took about 2 or 3 weeks to arrive.
Or get from Amazon.com (USA)
« Last Edit: August 02, 2020, 14:24 by dbchoong »
Denon AVR-X3600H * Polk S60 * S30 * TL2 * SVS 12
comfortablynumb
« Reply #453 on: August 02, 2020, 14:25 »
the pro is available on Amz US and price is S$312 inclusive of shipping to Sg
comfortablynumb
« Reply #454 on: August 21, 2020, 11:21 »
the shield pro arrived today and set it up to test; installed kodi 18.8 from playstore
again, the Moshou 8K hdmi cable (2m) was not compatible (just like with the zappiti and the zidoo z9x).
Switched to normal 4K hdm cable was Atmos was detected for Netflix and movies from my nas
Offline rock123
    • Bass EQ for Filtered Movies
« Reply #455 on: August 21, 2020, 11:52 »
bro change new short fibre hdmi cable tried?
« Reply #456 on: August 21, 2020, 13:11 »
Guys, the point of running fibre optic HDMI cable is when u need to connect to a display which is far away (more than 8m where some of the copper based HDMI cable will begin to display sparklies or intermittent loss of signal) from your AV gears. If you want to run anything shorter like 5m or less, then just get a normal HDMI cable with a High Speed Premium certified label will do. There is no value proposition in getting a short fibre optics HDMI cable. It’s expensive and will not improve your PQ all of a sudden.
All my fibre optics HDMI cable is at least 10m.
« Last Edit: August 21, 2020, 13:13 by desray »
Offline rock123
« Reply #457 on: August 21, 2020, 13:30 »
mine fibre is 12m too while short is all copper moshou.
What comfort bro encountered here is for short fibre hdmi issue wheres other bro have no issue with it for shield.
Awaiting change cable results.:)
« Reply #458 on: August 21, 2020, 13:31 »
Noted
comfortablynumb
« Reply #459 on: August 21, 2020, 18:30 »
Tested another 2m moshou cable and is working ....
The other cable goes to the bin lol
Offline rock123
« Reply #460 on: August 21, 2020, 18:51 »
Cool working now. Cable issue )
Offline econav
« Reply #461 on: August 21, 2020, 19:43 »
don’t throw , cut open and see for yourself what is inside.
All posts
Offline whyeme
« Reply #462 on: September 13, 2020, 15:26 »
Managed to get an Nvidia Shield TV Pro 2020 during 9.9 Shopee sales. After all discounts is $285 with one year local warranty.
Hall: Philips 65PFA4350/98. Oppo BDT-101CI. Rotel RMB-1512. SB Acoustics ARA. Dynaudio Contour SCX. Dynaudio Audience 42. PSA XS30. Plixir Elementa BAC 2500. Belden Studio 814. IsoAcoustics ISO-L8R155. Zidoo H6 Pro.
Bedroom: Plinius 2100i. Elac BS 204.2. iFi Zen Dac. Plixir Bac 800. IsoAcoustics ISO-L8R155. Belden Studio 814.
« Reply #463 on: September 13, 2020, 17:02 »
That’s very good price for a Pro model.
Offline stephensim
« Reply #464 on: September 21, 2020, 18:49 »
Just wanna share a forum thread on how to watch remuxed Dolby Vision (DV) mkv movies using Exoplayer via Kodi. This is a workaround solution at the moment as Kodi and Plex are unable to play DV mkvs natively yet. Plex in Nvidia Shield Tv can play DV in .ts and .mp4 formats though. The latest MakeMKV software (1.15.2) is able to rip the movie with DV and Atmos embedded. Read from page 62 onwards...
https://www.makemkv.com/forum/viewtopic.php?f=12&t=21937&start=915
In a nutshell, the steps are:
1. Installed Kodi from the playstore.
2. Installed Exoplayer from the thread - the file with name: Exoplayer_Chapters_Support_03_08_2020_no_debug.apk
3. Create a text file and copy and paste the below playercorefactory codes. Rename this file to playercorefactory.xml and add to Kodi under userdata (Android/data/org.xbmc.kodi/files/.kodi/userdata/ ).
<playercorefactory>
<players>
    <player name="ExoPlayer" type="ExternalPlayer" audio="false" video="true">
         <filename>com.google.android.exoplayer2.demo</filename>
         <hidexbmc>true</hidexbmc>
         <playcountminimumtime>120</playcountminimumtime>
    </player>
</players>
</playercorefactory>
You can use this method to access Shield in your Mac/PC:
https://support.plex.tv/articles/220347688-accessing-shield-storage/
4. Do not click on the Exoplayer app. It has to be played via Kodi. In Kodi, go to the mkv file, long press and hold and you will see a menu option being popped up, go to "Play Using..." and select "Exoplayer". Sometimes you may get "Playback failed", this is a known fault, just exit and try again and it should play well.
It works very well on my Nvidia Shield Tv Pro. I do not own other DV-capable players so this is the best way that I can watch DV movies for now. Not so sure if this method will work with other players though. Cheers!
« Last Edit: September 28, 2020, 08:59 by stephensim »
