Author Topic: 4k media player NVIDIA SHIELD Android TV  (Read 83005 times)
Re: 4k media player NVIDIA SHIELD Android TV
« Reply #420 on: October 31, 2019, 22:37 »
A new tubular-shaped NVidia Shield TV (2019)?! Hmmm... ???
https://www.theverge.com/2019/10/28/20935215/nvidia-shield-tv-2019-review-streaming-stick-dolby-vision-4k-price-specs-features
https://www.androidheadlines.com/2019/10/new-nvidia-shield-tv-2019-android-tv.html
Two things that strikes out to me...Support of Dolby Atmos streaming for Netflix is now possible and the other is the "new" AI image enhancer using a neural learning algorithm to achieve near 4K quality image for 1080p content.
« Last Edit: November 01, 2019, 10:29 by desray »
Offline francis wu
« Reply #421 on: October 31, 2019, 23:43 »
But no USB port for streaming from a HDD :P
« Reply #422 on: November 01, 2019, 10:25 »
Can get the Pro version which sports the same old design. That one have 2 USB 3.0 ports. This "new" version is targeted at streamer like Netflix, Hulu etc...
Offline francis wu
« Reply #423 on: November 01, 2019, 10:34 »
At US200 bucks, can this beat Zappiti or Zidoo on 4K streaming...any early adopters? ;D
Offline eggz
« Reply #424 on: November 05, 2019, 16:42 »
new Shield TV supports DolbyVision, so it's pretty cool. If only they added a dynamic tone mapping feature for HD10 content as well, then it'll be perfect!
Offline Norman_Chan
« Reply #425 on: December 13, 2019, 01:16 »
Does this Shield TV Pro able to playback ISO video file?
Thanks in advance for the reply.
Offline StephenBishop
« Reply #426 on: December 13, 2019, 18:49 »
Yes for the previous 2 versions (2015 and 2017) of Shield TV, via the Kodi app you can download on Playstore. But note that Kodi cannot display Bluray menu.
« Last Edit: December 13, 2019, 19:10 by StephenBishop »
Offline LWCM
« Reply #427 on: December 17, 2019, 13:05 »
Hi I am thinking of getting this as Kodi on my TV box always hang. Any issues to use kodi for this? Also what app do you use with this to stream videos from NAS?
Also how does this compare to Roku Ultra which is also 4k capable.
Offline escutcheon
« Reply #428 on: December 17, 2019, 13:25 »
Am running kodi 18.5 on the Nvidia Shield 2019, not the pro. Stream everything from my remote NAS nicely.
FHD, UHD, HDR, Atmos, DTS-HD MA, all good, except for surround AAC can’t decode to surround PCM. Could be a Kodi 18.5 issue as Kodi 18.4 seems to be able to decode correctly.
Other than this, everything else is good. I had lots of headaches to get HDR to work properly from all the other boxes I have tried.
Offline sijusid
« Reply #429 on: December 19, 2019, 15:52 »
For me, playing iso files in Kodi is a hit or miss. Whenever, something dosent play on Kodi, can use vlc player as an option
Offline sijusid
« Reply #430 on: December 19, 2019, 15:59 »
For the most part, Kodi works flawlessly on shield, once you add the nas on shield. I use Kodi (first choice) as well as vlc player. If you get the pro version, you can install Plex server also to access your files at home or remotely.
Only note there is no HDR support on YouTube.
I haven't used Roku ultra so can't comment.
Siju
Offline nur_hsc
« Reply #431 on: February 25, 2020, 09:33 »
Can new 2019 plays bdmv?
Offline noinimod
« Reply #432 on: February 25, 2020, 11:07 »
It can, with Kodi. Works beautifully btw. Some setup required but not fussy
