Author Topic: 4k media player NVIDIA SHIELD Android TV  (Read 89815 times)
Offline DizzyD
  • I am a HTphile !
Re: 4k media player NVIDIA SHIELD Android TV
« Reply #390 on: March 18, 2019, 22:53 »
I finally unboxed my SATV after 3 years!!
Spent 1 hour upgraded FW to the latest and also add SPMC n others.
This mediabox works like a true champ...Can play all formats and also iso too!
Connectivity to my Synology was a breeze too.
Super impressed!
« Reply #391 on: March 19, 2019, 07:48 »
Super impressed!
What took u so looong?!
Offline DizzyD
  • I am a HTphile !
« Reply #392 on: March 19, 2019, 12:31 »
was intended to be used with a 4k tv in 2016! LOL
But never gotten to buy it..those days the prices are premium
Btw am I right SATV cant play SACD ISO ?
« Last Edit: March 19, 2019, 12:40 by DizzyD »
« Reply #393 on: March 19, 2019, 13:50 »
Yes, it can’t.
Offline InnocentBlood
« Reply #394 on: March 19, 2019, 17:21 »
when you say it can play ISO files, do you mean DVD ISO files or BD and UHD ISO files with full menu navigation capability like what other players like egreat can do?
Sex N' Violence
Undesirable Publications
« Reply #395 on: March 19, 2019, 17:32 »
Nope...just simple BD ISO menu.
« Reply #396 on: March 19, 2019, 17:34 »
Another neat feature of nVidia Shield TV 4K is the ability to read MaxCLL and MaxFALL on 4K HDR rip in MKV format and this is very very crucial for 4K display. No other media player like Zidoo or Egreat does that.
Offline DizzyD
  • I am a HTphile !
« Reply #397 on: March 19, 2019, 20:04 »
SATV cant play BDMV folder which is non-issue as I can just play the index file will do...No full BD/DVD/UHD Menu is non issue for me too.
May I ask what is offered in eGreat and zidoo that SATV doesn't have? (besides full BD Menu)
Offline liverpudian
« Reply #398 on: April 01, 2019, 13:44 »
Thinking of getting the Shield TV & weighing 2 buying options:
1) via Qoo for ard S$280. Some customers reviews seem to indicate the set comes with SG 3 pins power adapter.
2) via US Amazon for USD190 (abt S$260) b4 shipping. Total costs will probably be abt same as via Qoo.
Like to check w bro who gotten their sets fr US....fr pics I saw seems like the power adapter is the “brick” type. Is the adapter universal voltage and if so, since it is the brick type can I simply swop the power cable portion with a 2 or 3 pins kind & reuse the actual adapter or is the power cable fixed to the adapter?
Finally other than the abv 2 buying options, anyone with cheaper lobangs ;)?
« Reply #399 on: April 01, 2019, 20:17 »
Not a brick type of power cable. Get the 2017 version with a much smaller footprint.
Sent from my CMR-W09 using Tapatalk
Offline congsterz
« Reply #400 on: April 02, 2019, 20:34 »
There are some limitations with shield. No DV or atmos support for Netflix, no hdr support for YouTube. You might want to consider chrome cast ultra or Apple TV 4K but check to see what they support first.
« Reply #401 on: April 02, 2019, 20:59 »
Bro congsterz is right...those are some of the limitations. So do ask yourself what you want from Shield.
« Reply #402 on: April 03, 2019, 09:49 »
I suspect it is a matter of time for the Nvidia Shield TV to offer Dolby Atmos on the Netflix app. after all, it has been doing this for Amazon Prime Video since late 2018 I believe.
Sex N' Violence
Offline congsterz
« Reply #403 on: April 03, 2019, 19:26 »
I wait until my neck quite long already.
Offline DizzyD
  • I am a HTphile !
« Reply #404 on: April 06, 2019, 19:44 »
I didn’t realized SATV can play DSD files using SMPC
Does it play as native or convert to pcm?
If native I will start ripping to dff files
Thx
« Last Edit: April 06, 2019, 20:06 by DizzyD »
