Author Topic: 2 subs better one  (Read 2581 times)
Offline sypderman88
2 subs better one
« on: January 26, 2015, 10:49 »
Hi Guys,
  Currently I am using single SVS PB 1000 currently located at front right. . I can get 17Hz in room response measure using calibrated mic. Will addint a second SVS PB 1000 brings major improvement in the bass quality, response and quantity ?
  Thanks.
Online Jag
Re: 2 subs better one
« Reply #1 on: January 26, 2015, 10:55 »
To give a better reference, why not post a screen shot of your in-room measured frequency response chart?
This way, the discussion would be more effective.
For sure, adding a second sub is going to improve quantity, quality. It's just a matter of hiw much an improvement we can get.
« Last Edit: January 26, 2015, 10:57 by Jag »
Online whitesox
« Reply #2 on: January 26, 2015, 14:52 »
Some brother goes for 2x12" subw or 1x15" or twin 10"driver sub.
Surely SPL will spread evenly and improve well when using 2 subw...
(how about use 2 x twin 10"driver sub  ;D)
but my own brother doesn't like too much bass...
« Last Edit: January 28, 2015, 08:20 by whitesox »
Offline sypderman88
« Reply #3 on: February 02, 2015, 13:05 »
hey...bought the 2nd sub liao....FR improves a lot...even low volume level thumping sounds very defined...bass sounds so clean...
Offline spells
« Reply #4 on: February 02, 2015, 13:40 »
bro which 2nd sub you bought ?
Online whitesox
« Reply #5 on: February 02, 2015, 13:53 »
Wont mind to share you setting on your both subw especially on Xóver ?
Offline sypderman88
« Reply #6 on: February 02, 2015, 16:22 »
bought another pb1000..position front left and right 1/4 length front wall from sides in a dedicated room..the 2nd sub smooth up the FR even before eq...then i set both subs volume to 12 clock..phase is 0...input to LFE only (aka disable crossover in both subs)..run audyssey..up the sub gain channel within 5dB of other speakers....the diff between two identical subs compared to one sub is huge in my room...
Offline sypderman88
« Reply #7 on: February 02, 2015, 16:23 »
i cross at 60hz for my mains...
Online whitesox
« Reply #8 on: February 04, 2015, 17:08 »
So... you set BIG for your front L/R huh?
Offline sypderman88
« Reply #9 on: February 05, 2015, 11:40 »
small...even though mains  and surround side are full range...u need to set small if want listen to stereo and activate sub through avr...
Now i use mix mode...cross at 60 is listen to stereo as integration with 2 channel is better..cross at 80 if watch movies for more SPL from sub..
Online whitesox
« Reply #10 on: February 06, 2015, 09:55 »
How about you set to big for front L/R (set at 80hz) than...
Place your two subwoofers behind and disable Xover so let your AVR take full control?
Will this setting be nice for movie ?
