Author Topic: MQA  (Read 65648 times)
Re: MQA
« Reply #525 on: March 13, 2019, 13:27 »
Tidal Master now available on iOS
https://9to5mac.com/2019/03/11/mqa/
With a few caveats - Airplay limits it back down to 16/48
And the iOS app doesn't support Chromecast Audio which would have done 24/96
Is the iPhone DAC capable of 24/96 internally or do you need an external USB DAC?
Offline MusicEar
Re: MQA
« Reply #526 on: March 15, 2019, 10:38 »
When I use Roon to stream to iPhone and Ipad as endpoints with Roon remote installed, Roon performs a down-sampled to 48kHz, this may suggest that the internal DACs are still operating at 48kHz. I've not tried using an external DAC.
Holo Spring NOS R2R level 2 DAC | Holo Audio Titanis USB Regen | Auralic Aries G1 | Seagate PersonalCloud 4TB NAS | I.AMP.D linear power supply for NAS | VTL 2.5i pre & VTL MB-125 monoblock tube power amps | Dynaudio Contour 1.8mk2 floorstanding speakers | Taralabs Reference Gen mk2 audio interconnects | Alpha Goertz MI-3 speakers cables & Chord Silverplus USB cable | W-Audio power distributor terminated with WattGate plugs | Lightning DS and Roon Core
Offline valenroy
Re: MQA
« Reply #527 on: March 15, 2019, 14:48 »
It has been while since I last posted and the recent hype in MQA has piqued my interest after my previous obsession with DSD...
What if I hint to you guys that you can readily download and permanently store ALL the MOQ files that is available on TIDAL with nothing more than a free TIDAL trial account and some hard disk drive storage... would you still have reservations in trying them out just for kicks?
*wink*
« Last Edit: March 15, 2019, 14:58 by valenroy »
Offline ginamos
Re: MQA
« Reply #528 on: March 15, 2019, 15:57 »
*wink*
waiting for more info :)
Re: MQA
« Reply #529 on: March 15, 2019, 17:07 »
With the current generation of iPhones, its internal DAC (“Apple 338S00248” CODEC) is only active when you use the phone’s built-in speaker/mic.  Otherwise it’s always digital out via the Lightening port (which can go up to PCM768/DSD256 no sweat). The internal DAC (likewise Apple’s $9 dongle) while capable of 24/96, depends entirely on the playback App and the driver used. With playback apps that use iOS’ native audio drivers, highres gets downsampled to 48k  ;D
Re: MQA
« Reply #530 on: March 15, 2019, 17:08 »
... What if I hint to you guys...
Guys, take it to PM or offline… you’re putting yourselves (and XP) at risk.
https://sso.agc.gov.sg/Act/CMA1993
COMPUTER MISUSE ACT
(CHAPTER 50A)
5.—(1)  Subject to subsection (2), any person who does any act which he knows will cause an unauthorised modification of the contents of any computer shall be guilty of an offence and shall be liable on conviction to a fine not exceeding $10,000 or to imprisonment for a term not exceeding 3 years or to both and, in the case of a second or subsequent conviction, to a fine not exceeding $20,000 or to imprisonment for a term not exceeding 5 years or to both.
Re: MQA
« Reply #531 on: March 20, 2019, 15:50 »
More MQA CD shopping....
Offline valenroy
Re: MQA
« Reply #532 on: March 21, 2019, 08:16 »
Hi Audio, do enlighten me on something. The MQA tracks on CDs are of a lesser quality than those found on Tidal (16-bit vs 24-bit) - am I right to say that? I have read on Meridian's website that the MQA tracks on CDs are limited by the 16-bit depth and it is not able to unfold fully like how the 24-bit versions are able to. Just want to clarify as you seem to be the only one around with MQA CDs at the moment. Thanks.
Offline malsound
