Author Topic: The spaceship is here  (Read 48516 times)
Re: The spaceship is here
« Reply #2 on: June 03, 2014, 16:18 »
Looks wild!!  ;D
Still, only a single GigE WAN uplink?... I would have expected with that kind of throughput, they'd have multiple uplinks (like Peplink Routers do).
Online domho8
« Reply #5 on: January 12, 2015, 14:56 »
Bro knight  these spaceships sure looks nice but chiat power type bo  :D
Offline Knight_Rider
« Reply #6 on: January 12, 2015, 16:44 »
Spaceship nice but overkill because no client has 4x4 antenna (bo usb adapter) so even give you 2 Gbps also no use it will not make your 600 mbps device any faster. There is now no device that can make full use of that power except the latest desktop with the latest motherboard.
Online domho8
« Reply #8 on: April 04, 2015, 17:59 »
Will this help to extend wider signal coverage.
Sent from my GT-N7105
« Reply #9 on: April 05, 2015, 15:33 »
What router you using? Asus RT-N66U and above no problem.
Online domho8
« Reply #10 on: April 05, 2015, 20:14 »
Buffalo Airstation, its at inlaws place and still using 15mbps broadband.  ;D
V weak wireless if its in the room.  ;D
« Reply #11 on: April 05, 2015, 21:05 »
$129 bo hua lah. Good router only $239. The $199 also not bad.
Online domho8
« Reply #14 on: September 03, 2015, 19:39 »
If I put this at hm, MIL will think its a cooker ha ha ha :)
New induction cooker.  ;D
