Author Topic: FS: S P E A K E R S  (Read 643 times)
Offline odomann
FS: S P E A K E R S
« on: May 01, 2014, 09:09 »
1.  QUAD  21L
Glossy piano black lacquer finish cabinets & drivers in excellent condition, Original Version (L1, not L2 or Classic).
http://www.goodsound.com/equipment/quad_21l.htm
http://www.reviewcentre.com/reviews11798.html
http://www.audioasylum.com/reviews/Speakers/Quad/21L/speakers/170039.html
Specifications:
Type: 2 way, 2 driver loudspeaker system
Frequency Response: 40Hz to 24kHz (+/-3dB)
Recommended Amplifier: 30 to 200W
Impedance: 6 Ohms
Sensitivity: 88dB/m/W
Bass: 1 x 170mm Kevlar cone
Tweeter: 1 x 25mm soft dome
Dimensions: 780 x 205 x 263mm
Last RRP: $1800
Selling @ $780
2.   RUARK Talisman II
Made in England, drivers & cabinets in rosewood veneer & black are in tip-top condition; there's a badge missing on 1 of the grills.
http://www.audioreview.com/cat/speakers/floorstanding-speakers/ruark/talisman-ii/prd_120538_1594crx.aspx
Specifications:
System Type: Bass reflex, 2 way
Drive units:
Bass/Midrange: 170 mm treated paper cone pure rubber surround, precision cast chassis, high flux magnetic system. Scandinavian-made.
Tweeter: 26mm precoated textile dome, dual chamber construction ferrofluid cooled and damped. Scandinavian-made.
Frequency Response: 46 Hz - 20 khz ±3 dB
Sensibility: 88dB/m /W
Crossover Frequency: 2,8 kHz (Precision audio grade components six elements)
Nominal Impedance: 8 ohms
Recommended amplifier power: 25 - 100W
Cabinet: Floor standing ACD, Critically damped MDF double layer construction
Colour Finishes: Real wood veneer in rosewood
Dimensions (HxWxD): 840 x 230 x 320 mm
Weight: 20 Kgs each.
Made in UK
Last RRP: US$1800 / £800
Selling @ $590
3.  USHER X-719
 Glossy piano black with cherry wood sides, both drivers & cabinets in mint condition.
http://www.audioreview.com/cat/speakers/bookshelf-speakers/usher/x-719/prd_327539_4290crx.aspx
http://www.stereophile.com/standloudspeakers/504usher
Specifications:
2 Way:   1 x 1" Silk dome Tweeter
               1 x 7" Carbon-fibre impregnated paper cone Mid-Bass
Sensitivity:88dB 1watt/1m
Nominal impedance: 8ohms
Frequency response: 38Hz~20kHz (+/-3dB)
Power handling: 80watts
Crossover frequencies:  2.0kHz
Weight :  38lbs (17+kg) Each
Dimensions(wxdxh): 27cm x 41cm x 40cm
Last RRP:  US$1390
Selling @ $990
                  If interested, please  SMS / WhatApp /  LINE :       93six8 5zero76
