Author Topic: Line Magnetic  (Read 45485 times)
Offline ks
Re: Line Magnetic
« Reply #60 on: May 31, 2014, 21:47 »
My untidy setup. :)
the floor stander is a Verity Audio?
TT: Thorens 160Mk3 with Shure M97xe, Scout VPI with Ortofon 2M Blue
Phono amp: CA 640P, **shopping for one**
CDP: Consonance CD120 Linear
Amp: **shopping for one**
Spkrs: Harbeth M20/M30
Offline louhan
Re: Line Magnetic
« Reply #61 on: May 31, 2014, 22:07 »
Hi ks, yes is a pair of verity audio. LM219 match very well with both pair of spks
ML39->SA102->S25
Offline louhan
Re: Line Magnetic
« Reply #62 on: May 31, 2014, 22:22 »
Robert say silver out of stock. This set was previously loan to atx2, bro when you want to clear your finger print on it. :)
ML39->SA102->S25
Offline louhan
Re: Line Magnetic
« Reply #63 on: May 31, 2014, 23:47 »
Hi Elton and Tiktokape, thanks.
« Last Edit: May 31, 2014, 23:53 by louhan »
ML39->SA102->S25
Offline Wooody
Re: Line Magnetic
« Reply #64 on: June 01, 2014, 02:09 »
One for LM fans. LM compression drivers!
http://truefi.blogspot.sg/search/label/Systems%20for%20Music
Can we get this here?
Offline j45yip
Re: Line Magnetic
« Reply #65 on: June 01, 2014, 10:22 »
...are these line magnetic products? not sure why they were renamed as LM22A and LM555 as these are obviously from WE originally. don't have the good fortune of experiencing the 555 but i heard the WE22A / Altec 290 combo with a 515 in the 825 cab and was impressed with the presentation.
a super tweeter (aka 3-way) is a must-have in this type of setup.
Vecteur D2 CD Transport, AN1865n-k Non-OS DAC
Thorens TD124MkII, MicroSeiki MA88, Expert Stylus 103 / Midas Touch
DACT CT100 / Custom Shunt Regulated PSU
5687 WOT Preamplifier
Behringer DCX2496
Type 45 SET monobloc / Radian950pb / AH204 Azurahorns
UcD180AN / Double Usher 15HM in Custom Vented Enclosures
Offline louhan
Re: Line Magnetic
« Reply #66 on: June 01, 2014, 11:53 »
LM also produce replicate WE amp and driver unit. Another amp i was considering was the WE124 LM replicate, Robert is able to bring in at $4.2k. But without being able to audition the sound, i took lm219 instead
ML39->SA102->S25
Offline louhan
ML39->SA102->S25
Offline j45yip
Re: Line Magnetic
« Reply #68 on: June 01, 2014, 15:17 »
WE 124 replica
Behringer DCX2496
Offline louhan
Re: Line Magnetic
« Reply #69 on: June 01, 2014, 15:59 »
Very nice vintage WE look.
ML39->SA102->S25
eltonng
Re: Line Magnetic
« Reply #70 on: June 01, 2014, 17:28 »
Hi all bros using the 5AR4 Rectifier tube. Currently using the LM518IA
Most info on the net says it can roll a equivilent GZ34.
The question is if I use a Mullard GZ37, any issues?
I heard the GZ37 will draw more current.
Ok some updates.
I rolled my tubes from the stocks to all Psvane
12AX7 to 12AX7 Psvane Tii
5AR4 to WE274
6P3P to 6CA7 Tii
The difference is huge. The moment the rectifier tube was replaced, the vocal appears to be tighter in the middle. With the 6CA7, the seperation is more prominent with better 3D imaging at the front.
All tubes available at Robert's place
Offline louhan
Re: Line Magnetic
« Reply #71 on: June 01, 2014, 19:57 »
I went down the same tube rolling path of changing to psvane Tii iexcept for the 310a tube. But since this loan set came without stock tube so was not able to compare the diff.
I also bought some WE310a. Comparing with the stock 310a, the WE got a smoother mid but lesser bass.
ML39->SA102->S25
Offline artaudio
Re: Line Magnetic
« Reply #72 on: June 02, 2014, 16:00 »
I went Factory tour on March 2014. Will upload pictures showing some retro WE stuff. and their full WE setup soon.
eltonng
Re: Line Magnetic
« Reply #73 on: June 07, 2014, 17:07 »
This thread is so quiet.
Some changes in my set up.
Removed Marantz CD 6004,
added in a Vintage Accuphase DP70.
Even this is a 20 year old CD player, I feel this CD player is a beast! Its like Wolverine, old and powerful and ever age. Even the younger generations of CD players cannot hold a candle to it.
Offline atx2
Re: Line Magnetic
« Reply #74 on: June 07, 2014, 18:21 »
Wait till u come to the dark side... N I'm sure u give up your CD ;D
Analog all the way...
