Author Topic: Audyssey Calibration - Tips in getting the best out of it...  (Read 92477 times)
Offline Drexter
  • To each its own...
Re: Audyssey Calibration - Tips in getting the best out of it...
« Reply #195 on: January 02, 2017, 01:42 »
Tried 80hz for LFE, bass tight and towards my liking... however felt that sometimes it feels a little fake. :) 120hz is realistic but not tight though and quite dispersed....
HTS setup
Display: Panasonic VT-20 50"
Source: Oppo 103D / PlayStation 4
AVR: Denon AVR-X4300H
Amplifier: Emotiva XPA3 Gen 3
Front LR: B&W 685 Black Ash
Center: B&W HTM61 Black Ash
Rear Surround: B&W MT-1
Subwoofer: HSU VTF3-MK4
Cables
Speaker: QED XT40
Preout: QED Performance
Subwoofer: QED Reference
HDMI: Mediabridge Ultra Series
Power Cord: AFA Aphrodite Series II
Accessories
Speaker Stand: B&W STAV 24
Speaker Spike Base from Gear
« Reply #196 on: January 02, 2017, 08:13 »
Read and followed. But not sure LFE should remain at 80hz or adjust to 120hz? Quit confused
Bro, I'm not sure what is the context of your question? Can elaborate further? Are you referring to the x-over for your main speakers (front left and right)? or Low Pass Filter at 120Hz?
Offline Drexter
« Reply #197 on: January 02, 2017, 18:35 »
LFE crossover.
Front speakers definitely go for 80hz
HTS setup
Cables
Speaker: QED XT40
Accessories
« Reply #198 on: January 02, 2017, 18:40 »
LFE crossover.
Did you read this thread (http://www.xtremeplace.com/yabbse/index.php?topic=222773.0) on the allowable range of crossover for your speakers? 80Hz is a good starting point for most bookshelf speakers and usually won't go wrong.
Offline Drexter
« Reply #199 on: January 02, 2017, 19:09 »
No wonder, my subwoofer crossover is 90hz max
HTS setup
Cables
Speaker: QED XT40
Accessories
« Reply #200 on: April 07, 2017, 07:16 »
Very disappointed with D&M...Audyssey just released the Audyssey MultEQ Editor App (not free, must pay some more!) on iOS and Android devices but D&M in all its wisdom and perfect business sense, decided that the X7200WA will not be able to use this app! This is the closest that Audyssey gets to be DIRAC imo. I just checked with Audyssey Chris Kyriakakis that the availability decision for the various models lies with the management team in D&M and they had decided only *selected models* released last year will be able to utilize this app?! WTF!!!
To read more: http://www.avsforum.com/denon-marantz-launch-audyssey-multeq-editor-app/
« Last Edit: April 07, 2017, 07:19 by desray »
Offline honyewl
« Reply #201 on: November 16, 2017, 14:41 »
Bought the MultEQ Editor App.  Works fine with my Denon X3300W.  Apart from additional graphical info, you get some additional features: mid-range compensation on/off, curve editor (didn't try), etc.:
My setup: Denon AVR-X3300W, Dayton Audio CBT24, KEF Q650C, Klipsch Synergy S-1, Rythmik F12
Online Jag
« Reply #202 on: November 25, 2017, 14:40 »
Ah, another proof that Audyssey intentionally suppresses infrasonic bass (bass less than 20hz).
« Reply #203 on: May 29, 2018, 11:45 »
Just an update in Audyssey news... The mentor figure of Audyssey had left Audyssey this month...
He is the chap that provided me with all the tips and guidance on how to optimize Audyssey calibration. This thread will not have been possible if not for his inputs...
Sent from my Vivo X21 UD
Offline HomeMovie
« Reply #204 on: August 02, 2018, 09:57 »
hi guys.
recently shifted to new place and bought a new Denon AVR and try to setup a 5.1.2. But after did twice Audyssey calibration, results still same, sounds boomy and like "blocked nose". wonder is it my rear speakers too "overwhelmed" as I'm using a MR2 on stand and it sounds loud and bassy like main speakers. Have tried to set -3db for rear, +2db for centre, still as loud.
Funny thing is the result after calibration as well.
Front 250Hz (Mordaunt Short MS207)
Centre 60Hz (Monitor Audio BX)
Surround 40Hz (Monitor Audio MR2)
Top Middle 80Hz (Earthquake ceiling)
results for Channel levels all zero, same as before calibration.
my floorstander at 250Hz? read some site and says usually audyssey will give a wrong front reading, others quite close. So ideally how much should i set it?
also, for the rear how can I lower the volume, there's no fader like our car stereo.
please help me.
Offline Bbos37
« Reply #205 on: September 27, 2018, 16:54 »
hi guys.
please help me.
Bro something is a miss in your main speakers crossover probably you need to recalibrate, my bookshelf speakers which is few feet away from the back wall and side wall turns out to 80hz and since yours is a floor-stander I’m the strong opinion on my remarks.
That said the rest of the cross over are ok but you my want to increase them a tad higher after audyssey.
