Author Topic: Lumin Audiophile Network Player  (Read 187954 times)
Offline bluetang927
« Reply #630 on: August 04, 2019, 13:12 »
How about teac nt505 streamer and dac and add a teac clock. Can use roon to improve on the remote experience.
Online wklie
« Reply #631 on: August 07, 2019, 15:16 »
Hi guys, can recommend authorized dealer shops in Hong Kong for Lumin products with good pricing?
Please visit us at Hong Kong AV Show 2019.  There will be a closeout sale of Lumin A1 (Silver).
« Last Edit: August 07, 2019, 15:26 by wklie »
Peter Lie
LUMIN Firmware Lead
Offline chimaera1982
« Reply #632 on: August 11, 2019, 13:28 »
Hi All
I've been using the Lumin U1 mini as transport to a denafrip terminator dac. I have one issue which is the controll app on Android. It tends to cut out a lot when I lock my phone and reopen the app. It takes some time even up to 3- 5 over mins to sync. Some times the sync will be stable but sometimes it's not.
WiFi is stable in my house using orbis mesh router. I had to use an extender to connect with Lan cable to connect to the Lumin. Could this be the weak link? Inputs are appreciated.
Thanks!
« Reply #633 on: August 11, 2019, 14:14 »
Hi All
Thanks!
Nobody use the Lumin app.
Use JRiver or Roon to stream your music to the Lumin.
« Reply #634 on: August 11, 2019, 14:41 »
Currently am using music stored on thumbrive that's plugged to the Lumin. The app is just a remote to control.
Offline Jsen
  • Diamonds are NOT Forever while Silence is Golden
« Reply #635 on: August 12, 2019, 11:22 »
Use Ipad to control the Lumin's app as the Androids' version sucks.
« Last Edit: August 12, 2019, 14:19 by Jsen »
Dynamics are the essence of how well you can feel the emotions and sentiments from the maestros and what they are trying to propose.
Online wklie
« Reply #636 on: August 13, 2019, 10:07 »
I have one issue which is the control app on Android.
If you have an iOS device, please try that.  Since Lumin players are OpenHome compliant, you may also use other OpenHome apps such as Linn Kazoo, Bubble DS Next, etc. for playback control.
Lumin app is only required for changing settings and firmware upgrade.
Peter Lie
LUMIN Firmware Lead
Offline thyewb
« Reply #637 on: August 31, 2019, 13:31 »
Hi Wklie,
I have been using Lumin U1 Mini for past 2 weeks. I plugged a 16gb thumbbdrive directly to the Lumin as music library. It was working perfectly fine until few days ago, Lumin cannot load the files in the thumbbdrive. I tried switching off Lumin completely and on again to reload the files, but later cannot find the files again.
The Lumin app showing "sda1" and "sda2" folders, but both are empty inside.
Kindly help.
Edited: Just tried Linn Kazoo app.. cannot find the files too.. problem with my thumbbdrive?
Sent from my Mi A1 using Tapatalk
« Last Edit: August 31, 2019, 13:34 by thyewb »
Online wklie
« Reply #638 on: September 04, 2019, 00:53 »
Please unplug the USB thumb drive.  Power cycle the Lumin.  After it is booted up and shows the progress circle on the front panel, then plug in the thumb drive again.
Peter Lie
LUMIN Firmware Lead
Offline thyewb
« Reply #639 on: September 04, 2019, 12:48 »
Hi Wklie,
Thanks for the reply. I will try it later when back home from work.
Also, what is the recommendation when not using Lumin?
1. Just leave Lumin power on all the time
2. Switch off Lumin from app
3. Switch off Lumin from app and switch off from the power button at the back of the unit
« Reply #640 on: September 04, 2019, 14:14 »
Hi Wklie,
Answer is (1) Leave Lumin on all the time and (2) switch off the Lumin display for longer life with the App.  The Lumin should then be on-standby.
Online wklie
« Reply #641 on: September 06, 2019, 17:30 »
I'd just leave it powered on (if not living in an area with unstable electricity), and make use of Idle Sleep setting that turns off the front panel (or just turn off the front panel).
« Last Edit: September 06, 2019, 17:33 by wklie »
Peter Lie
LUMIN Firmware Lead
Online wklie
« Reply #642 on: September 06, 2019, 17:33 »
Peter Lie
LUMIN Firmware Lead
Online wklie
« Reply #643 on: October 17, 2019, 12:27 »
Peter Lie
LUMIN Firmware Lead
Online wklie
« Reply #644 on: October 17, 2019, 12:28 »
Lumin app is updated for iOS 13.
Peter Lie
LUMIN Firmware Lead
