Author Topic: Lumin Audiophile Network Player  (Read 188363 times)
« Reply #600 on: April 17, 2019, 18:57 »
Post number #??
From #61.
« Reply #601 on: April 17, 2019, 22:12 »
Thanks I am on Synology...Dont seem to have Jriver
I was curious about this, so I did some digging for you… If you want to stick with your Synology, depending on your NAS model, you have one or both of the following options;
- Run the Virtual Machine Manager package under your Synology NAS, and install and run MC for Linux on the VM
Or (if your Synology NAS doesn’t have enough VM grunt)…
- Run the Docker package, and install the containerised version of MC
I’ve not tried the above myself, I’m not into JRMC, and I don’t use my NAS for Audio streaming, but seems others have and it works well enough ;)
« Reply #602 on: April 17, 2019, 22:19 »
.....or just get a cheap 2-drive QNAP NAS..like the HS-251 Fanless NAS.
« Reply #603 on: April 17, 2019, 22:26 »
True... Probably the easier choice if he's not into some Linux command-line activity  :P
Offline comfortablynumb
« Reply #604 on: April 17, 2019, 22:36 »
Agree just got myself a qnap 3 Bay wit raid 5 and 3 x seagate ironwolf Pro 6tb hdd for a dedicated music streaming
My other synology NAS is 4 Bay which I m using primarily for dsta backup n movie streaming
« Reply #605 on: April 17, 2019, 23:22 »
If you get a NAS to host your player, you are just dancing around.  End of the day, you will keep yourself a full blown server ....slowly, slowly, it will evolve into that.  Power is everything.
« Reply #606 on: April 18, 2019, 23:26 »
So one shot one kill to. Get a full blown PC with win server OS and running AO
Offline DizzyD
  • I am a HTphile !
« Reply #607 on: April 19, 2019, 20:58 »
Thanks AndrewC!
Offline wklie
« Reply #608 on: May 27, 2019, 12:37 »
Lumin (class AB) AMP photos and review (in Chinese) from a Hong Kong web site:
http://www.avbuzz.com/audio-video/201905/lumin-amp/
http://www.avbuzz.com/audio-video/201905/lumin-t2-amp/
Google Translate:
https://translate.google.com/translate?sl=auto&tl=en&u=http%3A%2F%2Fwww.avbuzz.com%2Faudio-video%2F201905%2Flumin-amp%2F
https://translate.google.com/translate?sl=auto&tl=en&u=http%3A%2F%2Fwww.avbuzz.com%2Faudio-video%2F201905%2Flumin-t2-amp%2F
(Note that the google mis-translation "(drum) is really dead" should be "to die for")
There is a promotion with purchase of Lumin X1 + AMP.
Peter Lie
LUMIN Firmware Lead
Offline chewed
« Reply #609 on: June 14, 2019, 13:38 »
Just received  my U1 today, now exploring the apps function and listening. So far very impressed with this product
Sent from my MAR-LX2 using Tapatalk
« Reply #610 on: June 14, 2019, 13:49 »
Welcome to the Lumin club.
What player software are you using?  You are playing on MP3....you need to stop this.
Offline chewed
« Reply #611 on: June 14, 2019, 13:51 »
that's the only files I have in my office... :'( :'(
« Reply #612 on: June 14, 2019, 14:06 »
OK, the older JRiver Media Center has a habit to convert your files to MP3 for playback in the DNLA server.  You need to set that option to "Original".
Offline BlurRhino
« Reply #613 on: June 14, 2019, 14:55 »
I just got a Lumin T2, about 30 hours on it now and I am slightly disappointed by the performance.. Or maybe I have set my expectations too high from the online reviews.. find that in my setup even though it has resolution, I losing a fair bit of engagement from music playback. The bass while excellent with the amazing layering, is also getting too much focus.
Just wondering does Lumin require a lot of run in to sound optimal? I currently connecting to my integrated tube amp using the balanced analogue outputs.
« Reply #614 on: June 14, 2019, 15:30 »
The D2 sounded quite engaging out of the box. But that uses Wolfson not the SABRE32 in the higher end models.
Sounded way better with balanced outputs
