Author Topic: Lumin Audiophile Network Player  (Read 188032 times)
Offline justubes
« Reply #465 on: May 11, 2018, 08:51 »
Yay!
Please keep us updated, once available!
With the fibre port, can it do AOIP via a fibre to copper converter if a dac supports it?
« Last Edit: May 11, 2018, 09:29 by justubes »
Offline wklie
« Reply #466 on: May 11, 2018, 10:04 »
No AOIP.  We still need MinimServer or Lumin L1 on the network to serve music via UPnP.
The fiber port can be used in these ways:
Network switch -> FMC (MC210CS) -> single mode fiber -> Lumin X1 with TL-SM311LS
or
Optical network switch -> fiber -> Lumin X1 with appropriate SFP
Peter Lie
LUMIN Firmware Lead
« Reply #467 on: May 11, 2018, 10:06 »
I would imagine with the X1,  we just tap the data stream from our Music Server / Music Streamer to the X1 and use a fiber to fiber connection, or at most using a fiber switch in between..  You only need Fiber Ethernet NIC cards installed in your PC.   This will remove the Media convertor I have at the Hi Fi rack feeding both Lumin S1 and Ayre QX-5.
Offline Tiktokape
« Reply #468 on: May 11, 2018, 10:11 »
Not yet, but hopefully soon.
Is X1 price going to be based on S1 or above S1? Will A1 be taken off the product ranges?
Offline wklie
« Reply #469 on: May 11, 2018, 11:33 »
X1 price is going to be higher than the current price of S1.  With the exception of D1 (replaced by D2), the whole Lumin product range continues to be available.
Peter Lie
LUMIN Firmware Lead
Offline wklie
« Reply #470 on: May 11, 2018, 11:38 »
Hmmm...  Do you mean setting up the PC as a router with its own DHCP server for the fiber network, then direct connect the Fiber Ethernet NIC to X1?  Lumin needs an IP address from a DHCP server, and it also needs to be able to stream from Internet Tidal / Qobuz / Spotify, etc.
As for using a switch that supports both optical fiber and copper Ethernet, yes that will work, but then you don't need the Fiber Ethernet NIC.
« Last Edit: May 11, 2018, 11:41 by wklie »
Peter Lie
LUMIN Firmware Lead
« Reply #471 on: May 13, 2018, 12:32 »
I was thinking of fixing the Lumin IP static. Then I physically swap the fiber lines within the LC connector carrier... I will do this if I am doing JPlay in the future.
Right now I am doing fibre all the way from music server, fibre switch to inject internet, to a Media converter just before the DAC so it is exciting that the DAC now has a LC socket.
« Reply #472 on: July 19, 2018, 02:00 »
Beyond my anticipation, I have gotten hold of my Lumin X1!
Hand carry it back....
The Lumin X1 now sports a Silver label instead of the S1's gold label.
Thicker and beefier power cable.
Initial Power-Up.
Power supply now have the "milled metal finish" as the Lumin X1.  Nice!
Yes, fiber everything!  Remove the media convertor from the signal chain and plug that LC plug directly into the X1!
This picture is dedicated to our #1 MQA fan in Xtremeplace!!
So mesmerized by the sound of the new X1, I scanned through all my favorite tracks for 3 hours straight.  Missed dinner! It is simply incredible.  The immediate impression you got from the X1 are the dynamics!!  Music is now more liquid, even more transparent.  Congested backing vocals now got space, separation and better definition.
I bought this without an audition.  Just based the decision on blind faith; ES9038Pro chip, fiber Ethernet, improved sampling rates and bit depth.  Worst case, I can just use this for MQA playback.   But now, this is my reference DAC replacing the Ayre QX-5.  Highly recommended.
« Reply #473 on: July 19, 2018, 07:01 »
Waah! :o Looks like a killer! Very smart design with the SFP :)
Online milk_vanilla
« Reply #474 on: July 19, 2018, 07:11 »
congrats Audio!
Offline Tiktokape
« Reply #475 on: July 19, 2018, 07:35 »
Congrats Audio on X1! Looks very nice!
Here are some pictures on the black finishing
http://www.avbuzz.com/audio-video/201807/lumin-x1-a/
Offline wklie
« Reply #476 on: July 19, 2018, 10:05 »
I'm very happy for you, Audio!  Sorry for causing you to miss dinner!  ;D
There are two ES9038Pro chips inside the X1 for dual mono operation.
« Last Edit: July 19, 2018, 10:36 by wklie »
Peter Lie
LUMIN Firmware Lead
Offline landis1
« Reply #477 on: July 19, 2018, 10:30 »
sorry i have not been following the thread but how much is the s1 and the x1 ? thanks!
Offline landis1
« Reply #478 on: July 19, 2018, 10:34 »
ok the x1 is about hk$8000 which is about s$1500 ;D
« Reply #479 on: July 19, 2018, 10:59 »
You're missing an additional Zero in those numbers!!  ;D
