Author Topic: Luxman L-540 Integrated amplifier  (Read 2540 times)
Offline nick696
« on: August 20, 2013, 14:45 »
Made: Japan
Condition: 8/10
Price: 1500
Contact: +60168828766 (nick)
Spec:
Effective output (8 ohms, both channel
simultaneous operation)    100W+100W
Class-A operation area:
15W+15W
THD    0.015% or less (8 ohms, an Output
power,
20Hz - 20kHz)
Cross modulation distortion    0.015% or less (8 ohms, 60Hz:7kHz=4:1,
Direct)
Input sensitivity/impedance    Phono man month: 2.5mV/50kohm
Phono
MC: 100 microvolts/100 ohms
compact disk, Tuner, Line1, 2, Tape1, 2,
Processor:150mV/50kohm
Balance/Line: 150mV/50kohm
SN ratio (an IHF-A correction, input
short-circuit)    Phono man month: 86dB or more
Phono MC:
74dB or more
compact disk, Tuner, Line, Tape: 108dB or more
Frequency characteristic    Phono man month/MC:Less than
[20Hz-20kHz±0.3dB]
compact disk, Tuner, Line, Tape: 100kHz
[ 10Hz - ]-less
than 1dB
Tone Compensation    The maximum variation: ±4.5dB
Power source    AC100V, 50Hz/60Hz
Power consumption    300W (based on a convention of Electrical
Appliance and Material Control Law)
AC outlet    Switched: Two lines, a maximum of 200W
Unswitched: One line, a maximum of 300W
Dimensions    Width 438x height 176x depth of 467mm
Weight    24kg
http://audio-database.com/LUXMANALPINE-LUXMAN/amp/l-540-e.html
http://www.thevintageknob.org/luxman-L-540.html
