Author Topic: Soundbar discussion thread  (Read 45065 times)
Re: Soundbar discussion thread
« Reply #210 on: March 06, 2020, 20:22 »
The Bose is very impressive
Get it when it’s on sale
I like the HK Enchant 1300 too
Offline Bonn
« Reply #211 on: March 06, 2020, 21:28 »
3K think can get the Sennheisser Ambeo soundbar. Not sure sound good or not. Any bros has listen to it yet?
Offline HDTV_noobie
« Reply #212 on: March 07, 2020, 02:27 »
Currently using the Sony HT-ST5000 soundbar and quite happy with it for its minimalist design and sound for both movies and music.
Good compatibility with most sound format including ATMOS and paired seamlessly with my Sony Bravia 65" X950G.
Online YANG
« Reply #213 on: March 23, 2020, 13:00 »
Panasonic's recent launch of Atmos/dts-X 3.1ch soundbars in UK and Australia are truly 3.1ch soundbars that do Virtual Atmos/dts-X processing without connectivity for wireless surround channels!
Offline Nizam
« Reply #214 on: April 15, 2020, 05:26 »
If you're looking for a soundbar to deliver a home theater experience without the need of multiple speakers and cabling, the Sennheiser AMBEO Soundbar could be the option you're looking for.
13 drivers to deliver a 5.1.4 experience in one housing, and yes with Dolby Atmos, 4K video-passthrough and eARC to name a few of today's requirements and also being a What Hi-Fi? 5 stars award winner.
But how does it perform? I do believe the end result is an engaging movie experience with realistic surround sounds.
The Ambeo mode is where the soundbar shines even further, brings the cinematic experience at the comfort of your home and even without an external subwoofer you still have your low end.
Of course the option is there if you wish to connect a sub for all the bass!
Offline rock123
    • Bass EQ for Filtered Movies
BenQ W2700 4K HDR   Source: Oppo UDP-203 & Zidoo Z9S
Sunfire Cinema Grand 5 Channel l Denon AVR-X4400H Pre-out @7.4.4
M&K Sound LCR950 THX Select2 Series  miniDSP 2x4 HD\WI-DG *BEQ*
SYS 1: Sub 1\2: Dual Rythmik FV18s  Sub 3\4: Dual Hsu Research MBM-12 MK2 (nearfield)
SYS 2: Dual Sunfire True Sub EQ , SVS PB12-Plus/2
« Reply #216 on: May 10, 2020, 13:15 »
Want something that will give you a blast, try the Dynaudio Music 7:
https://peteswrite.blogspot.com/2020/05/dynaudio-music-7-review.html
Online YANG
« Reply #217 on: May 10, 2020, 16:06 »
Zhun boh? SGD$???
by the time that reaches our shores... what kind of price will that be? if 6K, get ur "country pride" better!
https://sg.creative.com/soniccarrier/
Online YANG
« Reply #218 on: May 16, 2020, 17:45 »
Zhun Boh?!! Still lack of the 7*7=49 thumbs up power from local supporters lah!
Winner of American BassHeads Awards vs English BassHeads Awards
Who's better?
Offline jonchew
  • http://www.jjbizwebsite.com
    • http://www.jjbizwebsite.com/cbsearch/search.php
« Reply #219 on: May 24, 2020, 10:06 »
Sonos finally in atmos.
https://www.theverge.com/2020/5/6/21248430/sonos-arc-dolby-atmos-soundbar-announced-features-price-date
Anyone pre-order the Sonos ARC? The price is $1499 and is cheaper than Sennheiser AMBEO($3890) & Creative X-Fi Sonic Carrier ($5999).
Most of what we learn we learn from living
Online sevenz
  • Trade Count: (+17)
« Reply #220 on: May 24, 2020, 11:18 »
:o Wah 6k... the creative model so expensive ah.... can get very good separates already w the price...
Is it that good....
Carousell can get 3k + for used set
« Last Edit: May 24, 2020, 12:39 by sevenz »
Offline kickers
« Reply #221 on: May 25, 2020, 17:29 »
Thinking of getting the SONOS ARC, but there’s only 1 eArc input, my TV Sony KD-55x8500c which only support Arc and using UBP x700 uhd player. Wonder would it support Atmos??
Online YANG
« Reply #222 on: May 25, 2020, 18:37 »
Is it that good....
Seperates is for those who've space to play.
Soundbar is an easy and feasible solution to hv tight space orgasm... to ears i mean. ;D
Offline wcseow
« Reply #223 on: May 25, 2020, 19:40 »
1. TV need to support Atmos. The 8500c i think is a 2018 model. Not sure whether this model received the Atmos update. If u have Netflix on it, maybe do a search for atmos, click on the movie and if you see a Atmos logo, then tv should support. I used to own a X700 and I remember the Netflix app on it don't support Atmos, in case u are thinking of using that.
2. Even if the TV support Atmos, it will be lossy (DD+).
So I guess to be 100% sure, better get a Atmos soundbar that has hdmi inputs, then u can connect the X700 or other devices into it.
Hope it helps.
« Last Edit: May 25, 2020, 22:05 by wcseow »
Offline kickers
« Reply #224 on: May 25, 2020, 21:35 »
Thanks for the advice.  :)
