Author Topic: ONKYO AV Receiver Thread.. sharing of info and tech  (Read 191150 times)
Offline CASH
  • Trade Count: (+29)
  • Cash-96660233, Pasir Ris St 21, Blk 236, S(510236)
    • My Hi-Fi and H/T Set Up
Re: ONKYO AV Receiver Thread.. sharing of info and tech
« Reply #765 on: October 11, 2018, 16:05 »
Firmware update out!!
both my AVR's prompted me to update when I switched them on today.
dunno what it updates, but I jus carry on with the updates.
I LIKE EM, MEATY, THICK AND ROUND!!!!
http://www.hraudio.net/library.php?user=11189
Offline r0_ger
« Reply #766 on: October 11, 2018, 22:49 »
Yes. I just updated it too.
Sent from my ALP-L29 using Tapatalk
Offline jac5blues
  • EMOTIVA
    • jagsandhu1954@gmail.com
« Reply #767 on: October 12, 2018, 08:05 »
I did it too.✌️
Emotiva XMC 1 Gen 2
Emotiva Xpa 5  Gen 3
Emotiva XPA 2 Gen 2
Oppo 203
Marantz CD 5005
Dynaudio DM 3/7
Dynaudio DM center.
Emotiva E1 Surrounds
SVS PB 3000.
Cables:::: Mogami /Canare 4s11/BJC LC 1
Monoprice Hdmi
GW conditioner
Offline SiaOLiaO
« Reply #768 on: October 15, 2018, 10:37 »
Updated. Now with Amazon Music~ but i only use Tidal or Spotify for now.
- Onkyo TX-RZ730 - Epson HC4010 - Monitor Audio PL100 - Rythmik F18 - Monitor Audio PLC150 - Dali Opticon LCR Surround - Hivi VX8-SC Ceiling Speaker - Javes Motorised Screen - Xbox One X - Chord Epic Twin - Nordost Blue Heaven - AFA Aphrodite Power Cords - Belden Power Cords -
Offline reno77
« Reply #769 on: October 16, 2018, 08:58 »
Anyone's Arc stopped working after the update?
My hdmi cec got set to off after the update, so I set it back to on...
But still can't get the audio from the TV's YouTube app to play through the receiver.
The starhub box which I connected to bd/dvd works fine.
Offline SiaOLiaO
« Reply #770 on: October 16, 2018, 09:07 »
Sorry can't help. Not using ARC.
Offline r0_ger
« Reply #771 on: October 16, 2018, 10:11 »
No issue with my ARC.
Offline SiaOLiaO
« Reply #772 on: October 17, 2018, 17:33 »
I just bought a China-made power amp for testing to see its potential but after hooking up to the Pre Outs of the RZ730, I found out that the speaker pops whenever I change the inputs on the receiver. Previously I was only using the internal amps to drive the speakers and it was ok. Could it be the China made power amp?
Can anyone advise what is the possible problems if you have encountered similar issues before?
Offline reno77
« Reply #773 on: October 18, 2018, 08:59 »
My arc seems ok now, there's audio.. But volume icon doesn't show on the tv if I use the avr to control the volume when it's on arc..
Offline SiaOLiaO
« Reply #774 on: October 29, 2018, 10:53 »
So my fellow Onkyo RZ owners, how you find your RZ830/730 till now? I thought it sounds way better than my Denon 3311. Not sure if it's placebo effect and also the fact that I moved to a smaller place but i could feel more immersed in the movie than before. Music also sounded better even though the distance is shorter now.
Offline alan9
« Reply #775 on: December 05, 2018, 11:39 »
Thank you for Sharing your experience with us on the Onkyo TX Rz830. I m going to get this unit, this week. However also considering the Pioneer SC LX701 almost the same spec with a $200 additional premium. Hope any bros here can help me to decide base on your experience. My previous setup was Denon, Pioneer and Denon. After my last experience with SC LX56, I kind of leading towards Pioneer SC LX701. Had audition Onkyo RZ730 and find it also very nice too in PQ & SQ. Really appreciate any sharing here. Thank you
Offline Norman_Chan
« Reply #776 on: January 08, 2019, 10:46 »
After you select your sources , example HDMI 1 (BD/DVD) , on the remote control there is a quick menu button, when you press on it and under OTHER - HDMI , there is a selection of "Main" or "Sub" or "Main + Sub" , what to select ?
Anyone can enlighten ?
Offline vieri
Let my people go!!!!!
« Reply #779 on: February 14, 2019, 19:03 »
compare to marantz 5013, certainly lo...
However when put mano-a-mano with one another
v.s
The difference of $100 buys you additional connections, and u'll not be stuck on amplification like Onkyo.
Marantz have pre-outs on all channels, u can change ur amplification with another gear!
