ah yeah ure right.for now, can use a distributor full of sparkz and plug in to the main distributor? dunnoe if it can work that way.
You believe use many of these and the sound will keep improving? Sometimes medication if taken in big doses become poison. ; )
Note that threads get locked because the truth hurts
It is P, A, C, and D.
Yeah...Tesla Cell Sparkz coming out also..I would put it at the main outlet into the first Qx4 with a caveat that other powercords subsequent in the Qx chain is not too 'weak' before reaching distributor. If so, then connect Diamond just before the distributor.I got nine Qx4...all are getting Diamond powercords. They are also sitting on 5-tier Ansuz Darkz Diamond footers.The power chain has to be immaculate....the moment you plug any Diamond powercords into any Qx4 in the chain it is plain obvious how critical is clean good power to the components. One more cost effective way is to plug the first wall outlet and the distributor input with Diamond Mainz, then the middle ones connecting the Qx with Ceramic powercords. Proper placement will allow you serialise the placements so the cables can be shorter in length.I have tested that ASI powercords can synergise with Ansuz powercords (Ceramic and Diamond). So after the conditioner/distributor, one can consider still adding Diamond/Ceramic Mainz to close-by components and then connect via ASI or the upcoming ASI Reference powercords because their longer lengths is not wallet killing. Like I said earlier: Diamond> Ceramic> ASI. ASI Reference is still an unknown but it should arrive anytime soon and I hope to make a further comparison.Having a diamond Mainz in each Digital and Analog lines already can permeate its properties...the more Mainz added one by one...you start to feel the transformation into an amazing analog flow that is so addictive that I cannot describe using the right vocabulary....Woooooaaaaaahhhhhh!
