Author Topic: The Karan Amplifiers Thread  (Read 86595 times)
Online francishuang
Re: The Karan Amplifiers Thread
« Reply #30 on: May 27, 2013, 15:05 »
Beautiful sound lies in the ear of the beholder
EMT
Offline jimi
« Reply #31 on: May 29, 2013, 18:25 »
My agostino amp is one of the best no doubt after I fed it via torus giant voltage regulator driving my Giya speakers
The torus is able to supply way more than mains in 1/2 cycle at 120amps , 1 ,5 secs etc.
Whaa! You v hi end now bro :D One of my dream systems :)
« Last Edit: May 29, 2013, 18:31 by jimi »
Offline hmvc
« Reply #32 on: May 29, 2013, 18:31 »
Dun think so la, I saved up for it. Some bros buy in one shot and keep upgrading emm. My Cdp still a few k modded Plinius. Haha. Can't hear much diffs on exp cdps
Room ambience. R777x2. IPC energiser x2.
Offline jimi
« Reply #33 on: May 29, 2013, 18:33 »
That's a bit strange- maybe you need to listen to some really ex CDPs :D
Congrats bro
Offline wyaw
« Reply #34 on: August 14, 2013, 18:51 »
Any bros with kas400 or 600 can tell what's the height of the footer? And can I take out the footer?
Thx
no pain no gain
Offline 5th Avenue
« Reply #35 on: August 15, 2013, 23:04 »
Even if you can take off the footers...there the big screw for the transformer..thats around 10mm.
If u are trying to fit in a rack...u will hv prob
High end is not about the equipments but about the music it produce
Offline wyaw
« Reply #36 on: August 16, 2013, 10:32 »
Thanks for the info :) hope to hear some music from Karan tomorrow.
no pain no gain
Online blue_starfish
« Reply #37 on: August 16, 2013, 11:28 »
Karans do get warm in use. They need good ventilation all round to avoid heat build up. When putting in a rack, take air flow into consideration.
If you do not need the full power of the KAS400/600, KAS180mk2 is arguably the best sounding of the Karan power amps at a very reasonable price.
Offline wyaw
« Reply #38 on: October 03, 2013, 21:59 »
Anyone know how to take out the AC fuse of 270 at the back of the amp? there seems to be using coin to turn but can't seems to turn out.
no pain no gain
Online durianlover88
« Reply #39 on: October 03, 2013, 22:12 »
Screw-driver
For sale(neg):
Stillpoint Mini Ultra(3): S$299
Offline wyaw
« Reply #40 on: October 03, 2013, 22:16 »
thanks durian, think I found a better way.
Use 5cens push the button in, and turn counter clock wise. :)
no pain no gain
« Reply #41 on: October 04, 2013, 20:13 »
I am enjoying immensely the music that my KSA180mk2  is making. It's essentially the integrated minus the pre-amp section. Matched with Wilson Sophias, the music is luxurious, fast and very controlled with good PRaT.
Offline lkypeter
  • So much more to discover in classical music
    • Politics Economics Business Altruism Music Singapore
« Reply #42 on: October 05, 2013, 23:24 »
Met mystream today and heard his view of Karan and must listen to it but cannot afford to be poisoned.
http://lkypeter.blogspot.com
Gradient Revolution MarkIV Active Speakers,Ayon Stealth DAC,SoTM SMS200,NanoTech Golden Strada#301powercables,Synology1817+NAS,MacMiniCore2DUO8GB,YamahaRVX3067,SonyBDPS790,DenonX4000,PioneerBDP180
« Reply #43 on: October 06, 2013, 12:40 »
Acrolink 6100 is working fine for me. Lots of speed and dynamics. Did not do A/B with the supplied cord.
« Reply #44 on: October 06, 2013, 13:38 »
I bought my pair many years ago. Since then, there are better models in the Acrolink Mexcel range and prices have changed. Call X-Audio for a quote. But ball-park range will be $1,600 to $2,000 per 2m cable.
