Author Topic: Anyone Built A BoatAnchor Amp Before?  (Read 4798 times)
Offline ghemml
  • The Moody Cat
Re: Anyone Built A BoatAnchor Amp Before?
« Reply #75 on: August 21, 2012, 14:37 »
psu should be around 30kg and power amp around 35kg. that is my personal estimate base on the individual iron's weight specéd by manufacturers.
Man... that is a beast...!!!
Offline j45yip
« Reply #76 on: August 21, 2012, 20:43 »
...i can appreciate the task at hand  :) i'm sure the trolley is not a problem. just need to work out the transportation. i'll see what i can come up with. meanwhile, do let me know if anyone of you can help? i'm sure this GM70 is worth the effort!
bro.......if i can get assistance in the tranportation and trolley.....they can break my back really...i will see how things can work out....
Sony CDP XA50ES, Zhaolu D2 DAC
Thorens TD124MkII, MicroSeiki MA88, Expert Stylus 103
DACT CT100 / Custom Shunt Regulated PSU
5687 WOT Preamplifier
Behringer DCX2496
Type 45 SET monobloc / Radian950pb / AH204 Azurahorns
UcD180AN / Double Usher 15HM in Custom Onken Enclosures
Offline GAGA@echoloft
« Reply #77 on: August 21, 2012, 20:45 »
hmm....i think i must go chok chok William....:D
The Way Is Not In The Sky
The Way Is In The Heart
To attain Knowledge, add things everyday
To attain Wisdom, remove things everyday
Offline j45yip
« Reply #78 on: August 21, 2012, 20:54 »
...$1677 a pair, rated for this application, in today's context is not too bad eventhough i have yet to know how it will sound but i trust your judgement  ;D i remember the tamura F-2007 back then when frankie was still over the other side was already $2K plus.
Jo, mine is their Summit Series, ie. their 'higher' line, with teflon interwinding dielectric, dual C-cores.
678 Euros a pair. Shipping by EMS is a killer due to the large size and heavy weight of 25kg. 350 Euros.
In total i paid S$1677 after currency conversion.
Of course there are less costly units around. But after communicating and consulting the designer of Monolith, getting reviews by writing to some diyaudio members and looking at how well they document their products and tech specs, i have decided to order from them.
Jo, you may check their pricelist in their website. as well as shipping cost.
To add : checked price of Tango X10 with Larry, they cost a whopping $2.5k now!
Behringer DCX2496
Offline j45yip
« Reply #79 on: August 21, 2012, 21:02 »
...mammoth!  ;D luckily you have the right mind to separate the PSU and the signal halves.
Behringer DCX2496
Offline ghemml
  • The Moody Cat
« Reply #80 on: August 21, 2012, 21:19 »
Man... you guys are gurus of tube amps ;D
Offline neoinc
« Reply #81 on: August 21, 2012, 22:03 »
top plate sanded down....primer....buffed......primer....buffed.....primer.....buffed.......then paint .....buffed....then paint.....
a view of the finished amp...
The finishing is very nice. Can share what kind of primer and paint you used? Is buffing done by some buffing machine?
« Reply #82 on: August 21, 2012, 23:10 »
sorry, actual weigh in done...minus 5kg each...:D
« Reply #83 on: August 21, 2012, 23:21 »
neoinc, the primer and paint used is RustOleum brand. $25 a can from Self-Fix. I only managed to get the primer from the Vivocity outlet, which has a wider range of products. they are not cheap but has a good adhesion to aluminium surface. I have amps that are around 4yo with Rustoleum finish and the surface is still as good, w/o any peeling yet. buffing is done using very fine sanding sponge for wood or soft metal finishing - by hand.
Offline neoinc
« Reply #84 on: August 22, 2012, 00:03 »
Thank you! Will check them out one of these days.
Online BTW
« Reply #85 on: August 22, 2012, 01:04 »
Can be arranged...... ;) ;D
Offline puremilk
« Reply #86 on: August 22, 2012, 21:35 »
the curve tells the operation Va and Ia at optimise loading resistance n back current flown wich harmonics orders counted-in into tis parameter,sound imaging and stage are harmonics if you measure
them in a entire concealed sound-proof room............
« Reply #87 on: August 23, 2012, 01:31 »
this is something new to me but u have not answered my curiousity. How does 1200v and 120ma translate into soundstaging to u? how is soundstaging measured? in terms of what parameters?the curve is electrical characteristics, so how do u read it off the curve and translate into a non electrical result? if u have mentioned u experimented and experienced it, i will find it credible. I am solid state trained but i have done enough tube amps to understand the technicalities of things. so u may dwell into the technicalities of it, no problem.
hope u can explain further especially the 'back current'....... and 'loading resistance'..... and how do u count in these into harmonics to equate to soundstaging. harmonics are frequency components that can be measured off analyzer instruments right off your amp outputs. u do not need sound proof room....  or am i missing something?
Offline puremilk
« Reply #88 on: August 24, 2012, 00:42 »
very simple jus do an experiment on differ Va n Ia,Vg1 on ur GM70 with different loading and hear the result by yourself,you will find out liao.
I wonder why u need to do ur GM70 working in fix-bias mode?do you know why?how is ur damping factor affects the sound?think about it.
Offline puremilk
« Reply #89 on: August 24, 2012, 00:47 »
BTW:Tango X-10 is not a suitable output xtrans to play wif GM70 due to its max dc current.
store.singaporegoldsilver.com
Momocards.com
