Author Topic: Motherboard for HiFi  (Read 2118 times)
Offline 5th Avenue
« Last Edit: May 29, 2012, 10:40 by 5th Avenue »
High end is not about the equipments but about the music it produce
« Reply #1 on: May 25, 2012, 09:02 »
I'm always skeptical about such announcements and take it in the same grain (of salt) as Sound Blaster announcements that also tout hifi optimizations. They are good. For a PC level solution but not the type to match even an entry level hifi solution.
Re: Motherboard for HiFi
« Reply #2 on: May 25, 2012, 11:53 »
Wi-Fi or Hi-Fi? ;D
ProJect Q.
Re: Re: Motherboard for HiFi
« Reply #3 on: May 25, 2012, 14:44 »
Wi-Fi or Hi-Fi? ;D
What does the subject header says? :P
Sent from my GT-N7000 using Tapatalk 2
« Reply #4 on: May 25, 2012, 16:37 »
When I click the link I saw wi-Fi motherboard On header mah.
ProJect Q.
Offline 5th Avenue
« Reply #5 on: May 29, 2012, 10:44 »
Hahaha..there was a misconception on this as well.
HWZ posted a small note stating "Do not be confused as the press release on BIOSTAR's website has erroneously stated the new Z77 boards as "Wi-Fi" enabled."
Cheers.. ;D
Offline badbad2000
« Reply #6 on: June 15, 2012, 15:30 »
interesting, if a mini-atx broad will be great. build with small case with ssd.
Offline Furface
« Reply #7 on: June 16, 2012, 18:31 »
Reminds of A-Open had manufactured a full ATX board with 2 vacuum tubes for the sound output!
Sad thing it's costly durn then!
It was reviewed in PC Format Magaine.
